Säljer en 80-tals ikon i gott skick.
Saxat från nätet:
PG-380:
This was Casio's top of the line guitar, listing for about US$1500.
Body: Alder, longer than a Strat's and lacking the tummy cut and armrest contouring of the Strat, due to the numerous cavities routed in the body to accomodate the electronics.
Pickups: neck and bridge single-coil, bridge humbucker splittable by a pushpull switch on the tone control.
Bridge: Gotoh Floyd Rose-style (licensed) locking vibrato.
Neck: Maple with ebony 22-fret fingerboard; locking nut
Apart from the synth built in, the guitar itself, a strat style "Ibanez", is of very high quality. Adding the synth makes it THE MOST ADVANCED GUITAR EVER BUILT allowing the full transition from a normal screaming strat to a scary synthezised dentists drill by by slowly turning a knob on the guitar. Seen from the front it looks like a normal strat (S/S/H) with a Hex-pickup close to the floyd rose tremolo and a small panel below. On the panel there are 12 small buttons for controlling patches and octave, a 2-digit LED display, and two LED's for the built-in tuner. Strat-wise there is a five pole pickup selector and controls for tone, guitar volume and synth volume. Apart from a normal DIN MIDI-OUT connector there one mono output for guitar only and a stereo for guitar + synth. The synth can be set to send on six different MIDI channels, one for each string, or everything over one channel. Tracking is very good, and you can even bend the tones to play your favourite blues. The backside is full of electronics and a slot for the ROM cards. Acoustically it has quite a woody sound due to all the chambers routed for electronics.
Ett expansionskort följer med.
Caset är ett flång nytt Rockcase som knappt varit ut genom dörren.
3500 plus frakt (bussgods)
Förskottsbetalning till konto på SkandiaBanken
Fler bilder här:
http://yonaer.notlong.com
[SÅLD] OT. Casio PG-380
- pafal
- daionman
Byte mot bas?
http://www.alwayswar.com/" onclick="window.open(this.href);return false;
http://www.facebook.com/AlwaysWar" onclick="window.open(this.href);return false;
