Line6 POD X3 Pro
Taikesbass
Line6 POD X3 Pro
Inlägg av Taikesbass »
Säljer nu tyvärr min POD X3 Pro som köptes i augusti 2010. Den passar för såväl bas som gitarr och sång och är perfekt för studiobruk med en uppsjö av uttag m.m, men kan givetvis användas live utan problem. De båda kanalerna kan användas parallellt - ex bas + sång, eller tillsammans där man kör 2 simulerade förstärkare samtidigt till samma instrument.
Klippt från line6.com:
"POD X3 Pro is the powerful Dual Tone processor that comes fully loaded with amp and effect models for recording guitar, bass and vocals. In addition, a comprehensive array of inputs and outputs provide seamless integration into professional recording and performance rigs.
Like all members of the POD® X3 family, POD X3 Pro offers powerful Dual Tone modeling and routing options. Split your single-input guitar or bass signal through two different amp and effect chains simultaneously to create gorgeous new hybrids, or use its dual inputs to individually process two instruments—a microphone and a guitar, for example—at the same time.
Computer-based studios will want to exploit the USB 2.0 connectivity provided by POD X3 Pro for multi-channel recording as well as its S/PDIF or AES/EBU Stereo Digital Audio I/O for sending a direct digital signal to their DAWs. There’s also a digital Variax® connection that combines the acoustic and electric guitar models of your Variax with the amps, cabs, and effects of your POD X3 Pro. With the press of a footswitch, you’ll be playing virtually any combination of guitar, effect and amp.
For additional recording and processing flexibility, POD X3 Pro also includes POD Farm plug-in functionality for integration with DAW recording applications.
The comprehensive analog and digital inputs make POD X3 Pro perfect for a wide range of recording and performance scenarios. It features:
Dual 1/4" instrument inputs
Dual XLR microphone inputs (with phantom power, trim controls and low-cut filters)
Stereo 1/4" line inputs
S/PDIF digital input
AES/EBU digital input
Variax® Digital Interface (VDI)
POD X3 Pro also supports a comprehensive set of outputs for delivering processed bass, guitar and vocals to recording and performance rigs. Output choices include:
Stereo unbalanced 1/4" outputs
Stereo balanced XLR outputs (mic or line level)
Multi-channel USB 2.0
S/PDIF digital output
AES/EBU digital output
Whether you’re recording in the studio or performing live, POD X3 Pro delivers the flexibility, connections and timeless tones that have made POD® the global standard for the discerning guitarist."
Prisidé: 3700:-(frakt inräknat)
Ev del-/helbyten(där jag själv ev lägger till): 5-str jazzbas, kanske något annat
Bara att höra av er om det finns frågor eller med förslag på byten som jag inte tänkt på.
/Alex
Ibanez SR605, Peavey Foundation 2000(5-str), Line6 Pod x3 Pro, Ashdown Mag 300, Ashdown Mag 410, Laney Hardcore
Taikesbass
Bump
/Alex
Taikesbass
"Äntligen ändrat priset"-bump
/Alex
