Hej
Är intresserad av en Vanderkley Spartan.
Vanderkley Spartan
- Enbasist
- Elfström
Re: Vanderkley Spartan
Vanderkley Spartan finns här för direktleverans https://www.elfstrombassworks.com/vande ... artan.html
Features:
Input with 0/-12dB selection and mute
5-band active tone control, boost/cut with centre click;
Low -18dB/+18dB @ 40Hz
Low Mid -15dB/+15dB @ 90Hz
Mid -14dB/+14dB @ 600Hz
Mid High -15dB/+15dB @ 4kHz
High -18dB/+18dB @ 11kHz
Master volume
The pre-amp is built up from high-end, audio op-amps
Transformer Balanced DI out (mic level), Pre/post Eq, Ground lift
All signal switching is done with relays
Output A: 800 Watt @ 4 Ohm, 400 Watt @ 8 Ohm
Output B: 800 Watt @ 4 Ohm, 400 Watt @ 8 Ohm
High-end OEM two-channel class D power-amp
Switch-mode power supply
Universal mains, 100V - 240V
Ultra silent cooling fan
Weight: 5 Kg
h x w x d = 9 x 30 x 23 cm
It is two rack units high and comes with rack-ears for 19" mounting
Gig-bag for the Spartan is available
Handmade in the Netherlands
// Elfström
Features:
Master volume
Weight: 5 Kg
// Elfström
Shut up and play yer guitar!
