2000:-
"3-channel sat/sub full range professional amplifier, with integrated crossover network. Optional operation as a sat/sub amplifier or full range amplifier Internal crossover network for sat/sub operation Crossover network, selectable crossover frequency 80/120/180Hz Bass boost function (+3dB/+6dB) 2 temperature-controlled fans Ground lift switch Protected against short circuit and overheating LEDs for signal, overload (clip) and activated protective circuit (protect) NEUTRIK SPEAKON connections Technical Specifications Output RMS Subwoofer 4Ω: 1 x 400W RMS Subwoofer 8Ω: 1 x 250W RMS Satellite 4Ω: 2 x 250W RMS Satellite 8Ω: 2 x 175W RMS Max. power: 1,600W MAX General Inputs: 0.775V/30kΩ Frequency range: 20-20,000Hz Crossover frequency: 80Hz/120Hz/180Hz Bass boost: +3dB/+6dB S/N ratio: > 60dB Crosstalk attenuation: > 50dB THD: < 0.1% Power supply: 230V˜/50Hz/1,800VA Admiss. ambient temp.: 0-40 °C Dimensions: 483x90x390mm, 2RS Weight: 15kg Connections 2x 6.3mm jack bal 2x XLR bal 3x NEUTRIK speakon"
