SÅLDA: Aktiva scenmonitorer för medhörning
bassace
Inlägg av bassace »
--- SÅLDA ---
Säljer 3 st aktiva scenmonitorer för medhörning:
2 st Behringer F1220A pris 1000:-/st
1 st The Box MA120 MkII pris 800:-
Alla 3 för 2500:-
Finns i Malmö, skickas helst inte.
bassace
Re: Säljes: Aktiva scenmonitorer för medhörning
Inlägg av bassace »
Kompletterar med info från tillverkarna:
Behringer F1220A
"- High-performance 125-Watt active monitor system for live and playback applications
- Exceptional sound quality, wide frequency bandwidth and dynamic range
- Adjustable feedback filter and integrated limiter for ultimate system control and speaker protection
- Ultra-low noise Mic/Line input with Volume control and Peak LED
- Dedicated 3-band EQ for perfect sound shaping
- Powerful 12'' long-excursion driver provides incredibly deep bass and acoustic power
- High-resolution 1'' HF driver for exceptional high-frequency reproduction
- Proprietary horn design for ultra-wide sound dispersion
- Integrated 35 mm pole socket for stand mounting and use as PA system
- High-quality components and exceptionally rugged construction ensure long life "
The Box MA120 MKII
"120W (RMS @ 4 Ohms), high driver, 80Hz-16KHz +/-3dB, max SPL 120dB peak. 1 line input, 1 mic thomann input, 3-band EQ, level control with clip LED, XLR line output, SPK output for additional 8 Ohms passive monitor (4 Ohms load with both speakers connected). 35 mm Speaker stand flange, Rubber feet, Dimensions: 370 x 580 x 420 mm, weight 16,52 kg, thomann wooden cabinet with carpet covering"
