MythFX Infinium envelope/delay/ring minikombopedal
pnts
Inlägg av pnts »
Hittade den den här och tänkte det var väldigt mycket saker på liten yta:
http://www.mythfx.com/infinium.htm
The Envelope Filter mode features adjustable 'Q', Sensitivity, and wet/dry mix to accommodate your desired level of funkiness. The filter responds dynamically to your picking strength and works well with guitars and basses.
The Ring Modulator mode is just the ticket for spacey tones, and experimental textures. Chimey bell-like tones, gongs, and synth-like voices are attainable through your creative fretwork and the available controls. Additionally, delay can be brought into the mix with ring-mod processed delay tails.
Finally, the Delay Mode offers a versatile echo effect with adjustable delay time(up to 1 second), repeats, and wet/dry mix.
Har surfat runt men hittar ingen information som säger att den funkar på bas, varken 4, 5 eller 6 str.
Storleksmässigt är den ju ett "kap i miniformat"..
..någon som testat?
Pnts
