RockBoard® RBO Power LT XL
Inlägg av mrbaloo »
Tjena
Nu verkar Warwick ha kommit med ännu en produkt i serien med uppladdningsbara strömförsörjningar. Tycker att det låter bra jag även om det är ett koncept som Pedaltrain var före med.
Specarna låter bra också:
description:
The RockBoard RBO Power LT XL is a rechargeable power station for effects pedals, independent from the wall outlet. No more worrying about your 9V batteries dying mid song. You can also forget about searching for a wall outlet on stage to power your pedal board. The RockBoard RBO Power LT XL is equipped with powerful and long-lasting, rechargeable lithium-ion batteries, to supply effects pedals up to approx. 50 hours or more with hum free 9V DC current. Recharge time for the unit is approximately 7 hours.
Features:
•mobile rechargeable power station for effect pedals
•Charge while playing ability
•2 x separate 9V-DC-outputs
•Additional USB-output (5V) to charge mobile phones and smartphones
•Input for charger
•Battery charge level indicator with 4 LEDs
•Including: power supply/charger (5V 2A), 5 x 50 cm connection cables, 1 x polarity change adaptor cable 10 cm, 1 x daisy-chain cable (5 outputs), 1 x EU power cable 1.2 m
•Batteries capacity 6600 mAh
•Input charging time: about 7 hrs
•Standard color: black
•Dimensions (W x H x D): 114.5 mm × 22 mm x 58 mm
•Weight: 230 g
https://shop.warwick.de/?&c=35352344224 ... p_overview" onclick="window.open(this.href);return false;
Jag funderar på om detta kan vara bra för mig om jag även köper deras minsta pedalbord.
/MrBaloo
