Jag tänkte kika på denna efter jobbet men tänkte kolla med er här först.
I beskrivningen skriver säljaren:
"Det står Made in Japan på baksidan av halsen men jag kan inte garantera ursprunget."
Är det nåt jag ska tänka på? Känns annonsen legit? Kan det vara en fulloggad Rusta-bas?
http://www.blocket.se/stockholm/Precisi ... 9.htm?sa=1" onclick="window.open(this.href);return false;
//Pelle
P-bas på Blocket [Hjälp]
- pellesanslös
Fender Precision AV '62 | Fender Precision (Japan) | Fender Kingman
Orange AD200b MKIII | Orange OBC115 | Orange OBC210
- Falcon
Re: P-bas på Blocket [Hjälp]
Ser inte ut som en fulloggad Rusta-bas, men frågan om stämskruvarna är av de mindre modellen(typ mustang), och halsjusteringen kan vara på huvudet. Kan vara en omloggad Squier Silver Series eller Standard, men det är ju bra grejer.pellesanslös skrev:Jag tänkte kika på denna efter jobbet men tänkte kolla med er här först.
//Pelle
Eller Fender japan.
| Höfner 182-61 | Kent-63 | Audition-65 | Höfner 500/1 Cavern CT-13 | Höfner 500/1 Cavern Ri-17 | HB BB FL | HB B-25M | HPD Telecaster Bass | Squier P SSQ-00 |
I saw this and something doesn't add up.
The neck looks like its from a Fender Japan PB-70, but I've never seen a PB-70 in red or with a bridge cover, they also have a thumb rest in between the neck and pickup as was the case with mid 70's Fenders.
If it says 'Made in Japan' its likely to have been made sometime before 1997 as they changed to 'Crafted in Japan' sometime after this. I'd ask to see the serial number on the back of the neck to date it better.
From the picture the bass looks fairly new as there is no tarnishing on the tuners, control knobs or bridge cover which makes me think its not from before '97.
I own a PB-70 CIJ from 2004 with a rosewood board and white body, the only ones I've seen with a maple neck have a natural ash body.
I'd guess its a parts bass built around a maple PB-70 neck.
- Falcon
There´s an odd thing about "Made in Japan" if you check this:
http://www2.fender.com/en-SE/support/ar ... ct-dating/" onclick="window.open(this.href);return false;
- 200071
Annonsen borta...
- Falcon
Står som såld i min lista....
- pellesanslös
Jag var och kollade på den, men min magkänsla sa nej så jag backade ur.
Kroppen var omlackad och kändes som apelsinskinn. Halsen såg jag inga problem med.
Jag tror också att det är en hopplockad bas och det enda som är Fender är halsen.
