Säljer en EBS NEOGORM bascombo för 15. 000 kr
nypris 16.200 denna är 2 månader gammal (april)
info:
Frequency Response 40 - 18k Hz
Dynamic Output Power 350 W RMS
Continuous Output Power 300 W RMS
Cabinet Volume 78 liter
Height 70 cm / 28 tum
Width 58 cm / 23 tum
Depth 38 cm / 15 tum
Weight 36 kg / 80 lbs
Neodymium Speaker
9-Volt Phantom Power System™.
Compressor/Limiter
Powerful EQ including a BRIGHT filter
Tube-like Character switch
Serial/Parallel effects loop
Monitor input (1/4” balanced)
Possible to connect an external passive 4 ohms cabinet
EBS unique Silent Cooling System (SCS™)
Built-in speaker simulator
Stereo headphone output
”Soft-Clip”-circuitry provides tube-like overdrive
350 W RMS output power
All combos are equipped with side and top handles with detachable, lockable casters
EBS NEOGORM 212 350 W SÄLJES
