Dist?
- a-row
på wikipedia finns en lista över utrustningen som muse basist använder
http://en.wikipedia.org/wiki/Christopher_Wolstenholme
Big muff verkar vara en del av grejen, riktigt bra pedal, jag ska begravas med min
Fender Jazz 02 MIM,Music Man Stingray 97, Squier VM Precision 07
- cub
Läste en gammal intervju där han sa:
"I've been using Marshall DBS stuff now for some time. I've got 1x15 and 4x10 cabs and I've also got a Marshall B150 which I use for distortions and basically all my effects. I go from my bass into an octaver, and then into an Electro Harmonix Big Muff so those pedals can sort of go over everything. That signal inputs into an AB box, which splits to the B150 where I've got a couple of different distortions and bass synths. So the main signal going to the Marshall stays completely clean to keep lots of bottom end and then I just sort of an an edge through the combo."
Hang on; that means you can go into a distortion and then with the AB box you can add more distortion or effects?
"Yeah, I do sometimes every now and again! The Big Muff is the only distortion pedal that doesn't lose bottom end with a bass; you can have full distortion and stil get great bass. It's the green Russian one, but we found it in Japan and paid about 80 quid for it. There's also a Boss Turbo Overdrive that I occasionally use. I recently found a distortion pedal in Japan that insted of the usual red LED, it has a blue one so I always know when it's on! I've also started using Line 6 PODs in the studio and live."
- Bassplaya
Jag tycker gott att den Blowtorch jag äger räcker till för lite halvfuzzig basdist.
Bra pris också för en riktigt schysst pedal.
Kika under säljes, 1000 pix och då bjuder jag på frakten.
- Bassplaya
Om du inte tvunget måste ha en Big Muff, men ändå vill ha en Fuzz så finns det en till salu här:
http://pratabas.se/viewtopic.php?t=15714
- Hellish
- tomiko
Eller köp min sprillans nya TC Electronic Vintage Bass Drive. Köpte i julas men den var lite för fuzzig för mig...
http://pratabas.se/viewtopic.php?p=368959#368959
Fender Mustang, Gibson Thunderbird
