Billig balåda 1x15"SÅLD
Tomas
Inlägg av Tomas »
Yorkville BC115 300w 8ohm i nyskick.
har stått o samlat damm länge
pris. 1000:-
om någon är intresserad kan jag ta med den till glanshammar
vallebas
Inlägg av vallebas »
Den ser inte så dammig ut, snarare sprojllans ny med tags å allt.
Vad har den för mått och ung. vikt?
Börjar bli lite trött på Fenders deadspots.
Tomas
Inlägg av Tomas »
info från en sida jag hittade på nätet:
Instrument Amps Series
BC115 - Bass Cabinet - 300w, 15 inch
Compact and very efficient, the BC115 offers tons of bottom end without breaking your back or the bank. Careful attention to driver design as well as optimum enclosure parameters ensure that the BC115 will reproduce every note with equal projection. Use it alone or fit it under a BC210 or BC410 for extra thump.
Features
All Yorkville Bass Cabinets come loaded with quality custom designed Eminence speakers, made according to Yorkville's exacting specifications. Advanced computer modeling and extensive listening tests, combined with years of experience in designing high-efficiency P.A. enclosures, assure natural sounding, dependable cabinets.
Specifications
Cabinet Program Power (Watts) 300
Cabinet Impedance (Ohms) 8
Speaker Configuration - LF (Size / Power) 15 inch / 200 Watts
Frequency Response (Hz +/-3dB) 50 - 2,500
Dimensions (DWH, inches) 15.2x23x23
Dimensions (DWH, cm) 39x58x58
Weight (lbs / kg) 55/25
* Specifications subject to change without notice
