°SÅLD° - Phonic MM 1705a mixer
engson
Inlägg av engson »
Säljer en liten smidig mixer, som fungerar helt perfekt.
Pris: 700 kr plus ev frakt.
engson
Inlägg av engson »
Säljsnack på utrikiska:
Manufacturer's Description for Phonic MM1705A Rackmount Mixer
The Phonic MM1705a always delivers top results. Thanks to its excellent performance and cleverly conceived functionality, you can use it in the studio, too. On stage, this extremely rugged, flexible desk turns your work into child's play, even under the most demanding circumstances. From broadcasting to reporting, from MIDI/project studio to full-blown film production, this little magician can do it -- no ifs, just try it.
Features
5 balanced microphone/line input channels, two with insert points
3 stereo line input channels
2 stereo line returns
2T input and recording output
1 AUX and 1 effect mix send
3 band EQ for each line input channels
PFL for input, AFL for output
60mm high quality linear faders
Dual 13-segment LED level meter
2 audio groups
Stereo main output
Mono main output
+48V phantom power
-20/PFL, peak indicators on each input channel
AUX send can be set in pre or post fader
Low cut filter on each mono input channel
Hördudu den där kanske kan va' nå't...
PM!
