Panasonic Ramsa WR-DA7 / RME - Mixerbord+ljudkort+skrivbord
d'D
Inlägg av d'D »
Säljes ett komplett studiokit med mixerbord, ljudkort och skrivbord.
Mixerbordet är ett Panasonic Ramsa WR-DA7 som låter mycket bra och är både flexibelt och lätt att manövrera.
Kort spec:
-24-bit A/D and D/A converters yield over 110dB dynamic range
-Instant recall of all major mixer settings (EQ, dynamics, snapshots, etc.) via 200 memory locations
-Analog-style 1-step functionality (common mixer functions are only 1 step away, so you don't have to page through menus)
-38 channels (32 analog or digital inputs plus 6 aux returns) plus 8 buses
-Surround Sound: 5.1 mixing is built-in
-4-band parametric EQ on each channel (a total of 48 EQs)
-Dynamics section on every channel, including compressor/limiter, gate, expander and delay
-Automation: both dynamic and snapshot automation for all mixer parameters is built-in, with an optional automation expansion software package available
-Multiple interfaces: 3 rear panel expansion slots for up to 24 channels of ADAT, TDIF or AES/EBU connections are available
-Other option cards allow SMPTE and video sync, tandem connection of 2 DA7s and analog A/D and D/A connections
-4 fader layers: 21 high quality moving faders do triple duty as level controls for channels 1–16 (layer 1), 7–32 (layer 2), or aux sends 1–6, aux returns 1–6, and buses 1–8 (layer 3); the fourth layer allows you to customize your work surface by reassigning any of the audio faders and adding MIDI faders
-AD Converter : 24-bit 128X oversampling (INPUT 1 ~ 16), 20-bit 64X oversampling (AUX RETURN 3-6)
-DA Converter : 24-bit 64X oversampling (MASTER, MONITOR A), 24-bit 128X oversampling (MONITOR B), 20-bit 128X oversampling (AUX SEND 3-6)
-Internal Signal Processing : 32-bit (dynamic range 192dB)
-Fader : 100mm motor fader x21+ 10 ~- 90dB, -µ dB (128 step/100mm)
-Display : 320 x 240 dot graphic LCD (with backlight)
-Memory : Scene memory (snapshot) 50, Channel library 50, EQ library 50, Dynamics library 50, Automation 4 (event)
-Finish : Front panel: blue/black ABS; Rear & Enclosure: black steel
-Dynamic Range : (WCK=48kHz): 113dB AD Converter (analog in through digital output) typical,A-weighted 114dB DA Converter (digital in through analog output) typical, A weighted
-Sampling Frequency : INT:44.1/48 EXT.44.1kHz±3% 48kHz±3%
-Total Harmonic Distortion : Less than 0.1% (1kHz, +10dB input,+4 dB output, Rl=600 W: 20Hz
-Weight : 23 kg
-Width : 69.8 cm
-Depth : 54.9 cm
-Height : 24.4 cm
Ljudkort
RME Digi9636/52
-PCI Busmaster Digital I/O Card
-2 + 16 Channels Stereo / ADAT Interface
-24 Bit / 96 kHz Digital Audio
-ADAT Sync In
http://www.rme-audio.de/download/9636e.pdf" onclick="window.open(this.href);return false;
Skrivbordet är ett anpassat IKEA-bord med utdragbar T-bordsskiva.
Finns i Borås.
Paketpris för allt är 8000kr.
