Nya pedaler från NAMM 2014
Nu är en Darkglass Vintage preamp med DI på gång, kallad Deluxe. Förmodligen kommer den till NAMM 2014 om några dagar. https://www.facebook.com/photo.php?fbid ... =1&theater" onclick="window.open(this.href);return false;
(Byter namn på tråden så vi kan stoppa mer grejeri den här tråden.)
BasTore
Re: Darkglass Vintage Deluxe
Inlägg av BasTore »
Shiiiiit vill ha!!!! Skulle sitta fint bredvid min B7K!
Re: Nya pedaler från NAMM 2014
EBS har uppdaterat Valve Drivern med DI och kan nu använda 9 volt. Man kan dessutom köra den rakt in i ett slutsteg om man vill. Spännande.
STOCKHOLM & NAMM SHOW, JANUARY 2014
EBS announces the EBS ValveDrive DI!
The awarded original EBS ValveDrive overdrive/preamp pedal came out in 2006. Over the years it has collected high-profile fans like Justin Meldal-Johnsen, Sean Hurley of John Mayer's band and George ‘Goggi’ Holm of Sígur Ros for its ability to provide great classic tube amp bass sound - from a pedal! Now it's time for a revival! The EBS ValveDrive DI will be introduced at the NAMM Show 2014!
New outputs for extended use
The main new benefit with the ValveDrive DI is the XLR-output, offering a balanced floating signal that allows you to plug the pedal straight into the mixing console in the studio or at the gig. Add to that, the former standard passive output has turned into a low-impedance output so you can use the ValveDrive DI as a stand-alone preamp with an external power amp to give you the pure ValveDrive tone right out of your speakers.
New powering technique
There are plenty of pedals with a tube in it, but few deliver the warm fat tone of a tube amp. The original EBS ValveDrive was powered by a 12V AC power supply converted to high voltage inside to give the tube the push it needs to deliver real tube distortion. EBS has developed the ValveDrive DI to do the same using a 9V DC power supply. The benefit is a pedal much more compatible with standard power supplies.
The tube
The EBS ValveDrive DI is equipped with a superior quality tube.
Included accessories
The EBS ValveDrive DI comes with a 9V DC power supply included.
Price and availability
The EBS ValveDrive DI will be introduced at the WinterNAMM Show 2014, at the end of January. It will start shipping out of Sweden shortly after. Price TBA.
Visit http://www.ebssweden.com" onclick="window.open(this.href);return false; for further information.
Nya Valvdriven verkar ju lovande!!
T-Rex släpper nya pedaler också, den jag fastnade för var "Vulture" som ska vara lite special för att det ska enl. tillverkaren finnas massor med botten, dessutom definierad sådan, inte bara mummel.
Finns ratt för både low mid och low end så att säga...
Hittar ingen bild på den just nu, men det är en pedal i standardstorlek, mindre än T-rex vanliga paddor.
BasTore skrev:Shiiiiit vill ha!!!! Skulle sitta fint bredvid min B7K!
Darkglass Vintage Deluxe , 2633 kr hos Thomann. Lite billigare än B7K som är 3161 kr. Så när de finns hos TGT11 är det väl bara att slå till. ;)
Lite bättre bilder på EBS Valve Drive DI: http://ebssweden.wordpress.com/2014/01/ ... y-at-namm/" onclick="window.open(this.href);return false;
9v men 1000mA, ändå begränsat utrymme för att användas med trad. power supply-dosor...
