Rickenbacker 4003 jetglo (behåller)
moncho_myung
Inlägg av moncho_myung »
Säljer min Rickenbacker 4003 limited run jetglo pearlstars 1/30 från 2018
bara 30 st tillverkades
Ny skick
Inga repor .. fungerar fel fri
Original ric case samt kåpan medföljer
Först till kvarn
Skickas ej
Skambud svaras ej
PRIS :36900 kr
Body Type Solid
No. Frets 20
Scale Length 84.5 cm (33 1/4")
Neck Width at Nut 42.9 mm (1 11/16")
Neck Width at 12th Fret 54.0 mm (2 1/8")
Crown Radius 25.4 cm (10")
Body Wood Maple
Neck Wood Maple
Fingerboard Wood Maple
Weight 4.1 kg (9.0 lbs.)
Overall Length 113.8 cm (44 13/16")
Overall Width 34.3 cm (13 1/2")
Overall Depth 31.8 mm (1 1/4")
Neck Binding Yes
Fret Marker Style Black Dots
Tailpiece RIC
Bridge RIC
Neck Type Through body
No. of Pickups 2
Type of Pickups Single Coil
Output Type Mono and Stereo
Machine Heads Schaller Deluxe
