Lyckades även hitta denna här! Som också är överflödig för mig! Vet inte så mycket om ljudkort och så, så jag klipper lite från deras hemsida!
FEATURES
24-bit/192kHz Resolution for Professional Recording and Monitoring
Professional studio-quality recording in a portable desktop form factor
Featuring All-New Crystal™ Preamps and Pristine D/A converters
Capture every nuance and subtlety of your performance
Elegant Pro-Grade Metal Chassis
Large central control for easy volume adjustment
Future-Proofed High-Speed, Zero Latency Recording
Includes standard USB and USB-C connection cables
Dedicated XLR+1/4” Combo Input for Mic/Line Sources
+48V phantom power switch to accommodate all microphone types
Dedicated 1/4” Instrument Input for Guitar or Bass
Tailor-made gain and impedance stage for a pristine, accurate DI signal
Stereo 1/4” Main Outputs; 1/4” Headphone Output
With independent level controls
General Specs
Power: USB-bus-power
Dimensions 6.0” x 2.8” x 7.8
15.2 cm x 7.1 cm x 19.8 cm
Weight 2.0 lbs.
Click for More...
Requirements
Minimum System Requirements:
Standard USB 2.0 or USB-C Port
Windows: 7 (32 or 64 bit) OSX: 10.8
Pris: 500:- + eventuell frakt!
Finns i Klippan, SKåne.
